This should be posted with the thread linked below (but it has been closed).
https://www.turbodieselregister.com/threads/no-dome-light-when-opening-lr-door.264059/#post-2548704
I repaired the wiring harness between the B pillar and driver side rear door. The typical problem existed where the dome light did not come on after opening the door. Many of us have noticed that the sharp bends in the wire tend to eventually break wires.
Sure enough, one of the wires was broken. At least half of the wires looked like they would be broken soon. I was impatient and wanting to do the job on the cheap so I used some regular automotive wire that I had laying around (rather than ordering wire that is more appropriate). Here is an idea for an improvement which might make the harness last longer.
McMaster Carr has wire that is supposed to be more tolerant of flexing. One downside to this is the outside diameter of the wire is a good bit larger (a little more than double the OD of OEM wire). Not sure if the thicker wire would squeeze through the opening in the door 'grommet'. Search their site for ultra flexible wire. Abrasion-resistant wire is one choice that may work. This document shows the colors and gauge sizes of the wire. The link for abrasion-resistant wire is to 14 gauge wire. You'd have to buy 10-foot lengths.
I found that Geno's has the Mopar wiring harness. That's surely less hassle than cutting and soldering / crimping. Feel free to correct me, but I don't think Mopar has used a more durable wire in the replacement harness. My OEM harness probably lasted ~ 120K miles before wires started breaking so maybe we could expect the same from a replacement harness.
