Rear End fluid change
Magnetic fuel enhancer
CB mounting bracket for Sticks w/ cupholder is done
<font color=RED>I just got done changing my rear diff fluid over to AmsOil Ser. 2000 75W-90 gear lube. I am fairly curtain that I was taken to the cleaner by my dealer 30,000 miles ago. I paid $135. 00 for the dealer to change out the rear end and put in there Synthetic Gear (Castrol I think). The rear end cover had never been OFF. Did I just get screwed or do they just suck out what they can get? </font>
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Edgewood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil GL-4 80W-90 in Trans, AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends, Lund WInter front, Leer Cab Level Shell, 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
[This message has been edited by drawson (edited 07-26-2000). ]
If they did that, then they definetly SUCK.
1999 2500 24 valve A/T 4x4 loaded SLT Quad Cab Shortbed lim-slip 3. 54
How much did they nail you for the oil ???
95 2500,4x4,Laramie,Automatic,Emerald green,Equipment add on,Home made brush guard with fog lights,and modified block heater,2 pin removable,Cab guard protecter,which I hold the patent on it(making web page on it soon),cobra cb 148gtl, vent shades,4" open exhaust,TST power kit pk05,Triple pod pillar mount,Boost,Pyrometer,transmission gauges,Modified air filter box,silencer ring gone,
<font color=red>What I recall was the labor was $45. 00 and so $90. 00 for the fluid which come out like $18. 00 Quart for the Castrol S**t</font>
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Edgewood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil GL-4 80W-90 in Trans , AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends, Lund WInter front, Leer Cab Level Shell, 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
Something got sucked dry... ...
I think it was you WALLET!!!!
A new fluid pump is 5-15 dollars...
Amsoil is... ..... HMMMMMMMMM
Yup... DEFINATELY DRY WALLET SYNDROME!!! #ad
Larry
<font color=red>I had the rear end changed before I had joined TDR. </font><font color=orange> I called the dealer and asked about if it was common practice to just suck out the fluid and not pull the cover and they said it was. I told them that I was very unhappy with this and the service manager offered me a free oil change.
I don't think so</font>
Dee'sel
drawson,
I did mine when I changed to the Mag-hytek. I parked the truck on level ground & removed the cover. Then I rolled out the floor jack & raised 1 side @ a time & drained the axle tubes. I was surprised how much was in there! Don't get mad, get even, do it yourself next time. #ad
Money Sink - 96, 5 speed, SLT, 4X4, LWB, Ext Cab, ISSPRO pillar, TST 280/685 & AFC housing against the stops, Delvac 1 & Amsiol, Injectors, K&N, Monicas silencer ring removed, Exhaust brake, 4" CAT back & CATless, 4" chrome turn down straight out back, Mag-Hytec, 3:54, 235s, HX35s days are numbered, HX40 here.
<font color=green> Forrest I did just do it myself that is when I found that they hadn't pulled the cover. </font><font color=blue> I'm running the cool blue AmsOil Ser, 2000 75W-90 Now. </font>
Dee'sel
