Engine/Transmission (1998.5 - 2002) rear end swaps
Engine/Transmission (1998.5 - 2002) '02 HO turbo housing???
Engine/Transmission (1998.5 - 2002) installing probe in manifold
I need to rebuild my rearend here very soon and planning on installing a locker at the same time. What I am also wondering about is swaping in a newer rearend with a disc brake setup. What would be required in the swap? New brake lines back, different proportioning valve? Which year rearend should I use if I go this route?
Morph.
Drum to Disc
I would guess that you would need a different master cylinder and E-Brake cables as well.
Not much choice in years since they came out in 2001 (or was is late 2000) so take your pick
