Details here: TDR Privileges
Pulled into the bank this am and noticed a rear end vibration when parking. Level ground, crawling in first. Hoppity hoppity like. Definitely there. Not imagining things. Noticed it the rest of the am, at low speed (5-10 mph). Any ideas??
Have you had or changed the rear diff oil? Did they add or add enought of the limited slip additive? I added more then should and it works well. Try tight turns and see if the clutchs lock and unlock up. Hope this helps.
