rear end
Upgrade seats for 1st Gen reg cab
Pump timing and TDC
My rear differential is broken-the shaft holding the gears in place has sheared in half and the resulting loose metal has pretty much destroyed everything else. Took out the driveshaft and used the truck in front wheel drive, now I have caused a loud missing tooth sound from the front end.
Have found a used 1-ton,dual wheel,same ratio. Mine is single wheel W250. Question: Can I convert the dually to single wheel without much trouble?
How did I break such a robust rear-end you ask? Plowing snow for 8 years, sometimes for 3-4 days straight thru with two drivers, constantly in four-wheel drive. Pushing snow uphill and around corners you would hit a spot of dry road. Under nearly full power you can imagine the strain between the front and rear wheels. I would replace front universals every 2 years! I'm not complaining, the truck has outlasted every other vehicle plus even with the broken shaft it has kept on going! I might add that this truck has paid for itself and then some.
What axles do you have now, and what gear ratio ? I have 2 sets of 4:10 gears laying around. As for the dually rear end, the off-set is different that a non dually.
Kyle
rear-end
Thanks for the reply. Should have mentioned details. Gears are 3. 54, limited slip, Dana 70 in a 92 W250 extended cab 4X4. I have been quoted $1300 to rebuild my present unit. Hoping to find a less expensive solution- used rear end with good brake drums would be great as my present drums are beyond refacing.
