Well I'm a little late, but I finally finished making five rear freeze plug installer tools. I know there were a couple of threads a while back with some of the guys blowing the plugs out, and saw a need for a tool that works with the engine and transmission installed. With this tool you don't need to pull the transmission to reinstall it. The freeze plug goes over the installer and sticks to it with a dab of silicone. You install three bolts and it pushes the plug into the block and sets it to the correct depth. You can then remove the tool or just leave it there to keep the plug from coming out again. The tool is 3/8 plate and the freeze plug holder is machined from aluminum. I also made some 1/8 plates that bolt to the back of the block to keep the plug from coming out if it has not already come loose.
I just need to test fit the installer and take a couple of photos of an install showing the coolant line that is in the way at the back of the block. It is a “by feel” install, so a good visual of exactly what is back there will be most helpful. The installer is also drilled to push in the plug at the exhaust side of the motor in the rear. It uses the standard Mopar 68005064AA freeze plug. There were a couple of threads that mentioned an oversize plug, but I was never able to locate a source for one.
I have not decided if I want to sell them or loan them out like the KDP tool. I have quite a bit of time in the making, mostly in machining the plug holders, but now that I have made a few and know what materials I need it should go a little faster. So I guess I need to know the demand out there.
I should note this fits third generation trucks only.
