Okay decided to wash the truck yesteday as it was a beautiful day, glad i did, left rear hub leaking, make a long story short, thats the side that got a new seal and new axle nut. . Hub is loose, pulled wheel and axle, Push in on hub and have some movement, going to get axle socket for nut this morning to tighten up, so far i don't think there was enough play to mess up the bearing, might have messed up the seal im not sure, going to tighten axle nut to where hub has no movement and put back together and see if it leaks anymore. To the best of my eyes no damage to anything just alittle hub movement, enought to cause leak, could have been that way after bringing from the shop, as i noticed oil on the inside but brushed it off as oil from where it has gotten on their the day of the work. .
We will see... .
We will see... .
