Just finished setting up my “back-up” lights. The relays are located above the spare tire. The PIAA cast a 25 degree beam, and the KC Flood lights cast a 180 degree beam. The UP position is wired to the battery so no key is required. The middle position is “OFF” to avoid reflection if connected to the white trailer, and the down position has the lights come on with the standard backup switch (reverse lever).
The small lights tucked inside the bed (one each side) help to illuminate the black Line-X bed with the BakFlip cover closed at night. They are small enough that they don’t require a relay and are connected to the battery.
