I have a spreadsheet I created awhile back that calculates deflection, spring rates, etc for semi-elliptical leaf springs.
Just for fun, I ran some figures.
Consider a rear leaf spring pack with 8 leaves, each 3/8" thick and 2. 5" wide, with one leaf extending all the way to the end, with the stock dodge length from eye-to-eye. The thickness in the middle where it sits on the axle is 3". The effective spring rate at static, assuming a vertical shackle, is 647. 4 lb/in. A stock truck regular cab truck would compress this pack 1. 26" just sitting static. With 2500 lbs in the bed, the total compression would be 2. 65".
Now consider a leaf pack, identical to the first, except there are 12 leaves, each 1/4" thick, with 2 leaves extending to the end. The leaf pack is still 3" thick in the center... the exact same as above. However, the spring rate is now 293. 4 lb/in, and the static unloaded deflection is 2. 78". With 2500 lbs in the bed, this pack would be compressed a total of 6. 19".
Quite a difference.
--Eric
Quite a difference.
--Eric
