Spring Spacer Removal
On Sunday afternoon I removed one of the spacers under the spring. They are held in place with two bolts through the spring. After removing the rear wheel and the u-bolts I let the axle down enought to remove the bolts from the spring and remove one spacer. When I reinstalled the bolts through the spring I used a spacer washer before installing the nut so the bolt would have enought threads to the to secure the remaining spacer to the spring. Before I removed the bolts that hold the spacer I put 2 c-clamps on each side of the area where I was working to hold the spring together just in case it tried to separate. The first side took about and hour to get all the tools together and see what had to be done. The second side took about 30 minutes. As far as I can tell it dropped the bed down a little over 1/2'' which is what I needed. Everthing seemed to have plenty of room under the truck. I'll let everyone know if the there is any problem
J Ashcraft
2004 Ram 2500 Reg. Cab, lwb, ho, 48re, 2wd
