2nd Gen Non-Engine/Transmission rear spring u bolts
Engine/Transmission (1998.5 - 2002) Head Gasket let go
I was just wondering if anyone has taken off there overloads. I did this tonight and had to put the truck back together for work so I used the spacers so the u bolts would reach. Is this safe to do. Thanks .
They shouldn't be reused as Nate said..... your local spring shop should be able to make you a set to fit your needs.
Overloads
eherrera said:
Thanks Guys.
I had mine removed years ago in order to get rid of "overload slap". The factory overloads don't even begin to work until the truck is grossly overloaded. New u-bolts are a must.
