brakes
Here is a copy of an earlier post about using the GM wheel cylinders. I just ordered 2 but have not received them yet.
http://www.napaonline.com/cgi-bin/n...tail.d2w/report?prrfnbr=15557287&prmenbr=5806
GM wheel cylinders put in today... ..... day and night!!!!!
Took me less than 2 hours ( with clean-up and garage floor mopping) It is incredible how much better it brakes now. $30 something verses $600 for an exhaust brake is A-OK for me. I don't tow anymore, but I wanted to save myself the $ and headache of pads and every 6 months. THANK YOU to whoever gave the tip and NAPA part #'s... ... ..... I cant remember who it was. I am so stoked, now I can use the money I planned on buying Banksbrake for more mods.
Putting a little bit bigger rear wheel cylinders on the rear end of the older trucks to make the brakes work like they should have from the factory.
All the way up till the rear disc brakes came out, '01 or '02???.
Biggest advantage is on pre '97 2500s where the cylinders were 24mm but on 3500s and all post '97 trucks (27mm, the largest Dodge used) you definitely see an improvement as the cylinders GM uses are 30mm. There was a post here where someone figured out the increase in braking force as related to cylinder diameter. I don't remember the numbers but the percentage increase per mm was quite impressive.
Checked with NAPA and they said they have two versions of the SAME wheel cylinders:
4637337 $11. 49 (website price) TSW4637337
and
37337 $41. 49 (website price) UBP37337
The second number is supposed to be the "premium" one. What would be the difference in a premium wheel cylinder? <<... OLE_Obj... >>
See this link
http://www.napaonline.com/cgi-bin/n...rt_number=37337 <http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_part_num. d2w/report?Search_Part=YES&pn_exact=NO&part_number=37337>
The brake expert who originally told me of this mod said to use the cheap ones, that there is really no difference except price. I installed some of the expensive ones for a guy who said he'd rather "Buy American". On close inspection I can't tell the difference between the two and both are made in the US. They even weigh exactly the same.
Then my buddy who owns the local Napa clued me in on the real deal in the difference between the two. Professional mechanics like to use the more expensive ones because most mark the price to the customer up a set percentage. 10% of $41 is four times more profit than 10% of $11
