I have the slider rear window and noticed this weekend that it is leaking. I have it at a local glass shop, and he verified the leak.
It is definitely not the rear brake light.
The water gets in where the fixed glass, and the slider meet. According to the glass shop, this is by design. There are several small weep holes in the track that drain any of the water that gets by. As long as there is not much rain this works fine.
The problem with this is when you get 4 inches of rain in a day the drain holes can't keep up and you get a "wet carpet".
The shop has verified all the seals are working properly and he doesn't have a good answer on what to do.
Should I replace my slider with a solid glass window?
Btw, this is the 3rd rear window I have replaced.
