Rearend oil was a little dark!
auto trans cooler lines
IS GL-4 OBSOLETE?___REVISTED
I went to the 4wd shop yesterday to count the splines on the axle to make sure we got the right locker for my truck. As he pulled the axle to count I noticed the oil was fairly dark. I know that does not really mean it is bad or need changing but I will be changing about every 25,000 or a tad sooner. It has had some good loads on it and the guy did say it is a good idea to keep the synthetic fluid. Truck has 22,000 miles. Will be getting my locker soon!
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
sounds good okie,
I only have 10k on mine and mostly empty but with a lot of freeway miles.
I plan on changing mine about the same time. what locker did you get ARB air? If I was to get one I might get that one.
Eric
2001 QC 2500 4x4 bronze W/two tone Driftwood, 24valve HO 6sp. Westin side bars, fender flares, Rancho RSX off-road shocks, Spray on bedliner, Leer shell Painted to match with LED marker lights, Bf Goodrich AT Tires. Bed rug inside shell W/aux marine deep cycle batt for lights, etc. M Brolins' CB mount.
Name of rig is "big bronze Brute"
I am going to get the loc-rite. It is made by powertrax. Good unit. The shop manager said it will hold the cummins and the 6spd and will do what I want. He put the same one in several trucks and has no problems so far. Of course I kinda wanted a Detroit but I did not want to change to a 4. 10 gear.
