ok here is the deal had a bad oil leak started looking for teh leak found it a bolt behind teh cam worked itself out therefor lettign the oil seep out between the gear housing and the block. so I riped out the engine and transmission had to send back clutch to get fixed.
here are the questions
1. should I go back with stock cummins gaskets (if not which kind should I use)
2. what brand of pistions should I use (not going to bore head)
3. does anyone know if there are any aftermarket motermounts(any with polyurathane) (craked both of mine)
4. does any one make a polyurathane bushing kit for the dodge
5. is there anything else I should do
thanks for the help
Daniel Rice
one more question
why doesn't anyone design a twin turbo that uses a split manifold and 2 HX35's one off of 1,2&3 and one off 4,5&6 then TRUE dual 3- 31/2 inch exhaust.
just a question maybe there is a reason.
thanks for the help
Daniel Rice
one more question
