Vaughn MacKenzie
drice, as I recall you had about 230,000 miles on your rig? Maybe there was a defect with the head gasket or the head is slightly warped that could be causing your blowby??
I am trying to remember some specs from doing some engine work before, but only . 002" wear is like pretty miniscule. . .
Can you see or catch any edge at the top of the cylinder where the rings have worn?
Evan Beck had a head off a Ram with 260,000 recently for a gasket and found the cylinders in perfect condition, no detectable wear. As much as he's torn into diesels it is still impressive how little wear the Bs have at high mileage.
Vaughn
Vaughn
