Race engine VS Street or long milage engine
thaile, can you take a few photos of the wear you are describing on your engine?? Have you checked ring gaps to see how worn the rings are? As asked above, is there a ring ridge? or scored cylinder walls?? Can you post a photo of one of the worn bearing shells? Currious folks would like to see!!
As for air filters:
Guys think about it: if an engine is going to only go a few hundred miles in the case of a road race or Indy car or only a few miles like a drag car before it is completely torn down, rebored or honed, rings, pistons, bearings replaced, the quality of the air filtration is secondary to air flow, hence the use of a filter of the type being debated. Or in many cases there is NO FILTER so does this mean that since a AA Fuel dragster with a very expensive engine uses NO FILTER then we should do the same on our Cummins engines??? I don't think so!!
I tend to believe that in many cases an air filter is put on some race engines only so that the car can be sponsored by the air filter company! Creating advertising so that the general public will go out and buy a 'race filter' for their 'race' grocery-getter, it's GOT to be better, the race cars use them!!. Give me a break.
The long-milage over the road trucks use a tri-phase type filter: a screen to filter out the bugs and rocks, then a centrifigal spin is put on the air to spin out the sand/grit, then a paper filter is the third phase of filtration. This type of filtration is seen on farm equipment that work in the worst of all dirty environments. All my John Deere, Case and Caterpillar equipment has or had this type of three-phase filtration.
I've spent a lot of time and years turning wrenches and rebuilding engines, and I've never seen an engine that had worn out rings and bearings from anything but DIRT!!
If overheating was the cause of engine failure, then there were cracks in the head,or cylinder walls, melted pistons that made the rings stick in their grooves or lands, collapsed piston skirts, or burnt valves. Bearings that are damaged by heat are burnt and scored, not worn. Wear is caused by abrasives in the air and oil. Keep the air clean, and the oil clean and the engine will reach it's intended lifespan.
How many threads have been posted on this site saying that after hundreds of thousands of miles their Cummins' cylinder walls still had cross-hatched hone marks still visible?? That is the result of good air filtration.
If ya like the air filter you are using, be happy, I'm happy with my choices.
Greg L. The Noise Nazi
