The only "module" recall I have heard about deals with possible corrosion on one of the connectors. They inspect the connector. If there is no corrosion, they install an o-ring to prevent it. If they find corrosion, they replace the module.
Hope this is what you were talking about.
Also if you have an automatic, there is a recall on one of the transmission cooler lines.
