Any link to the HT door set up ?
Mostly complete write-up.
https://www.turbodieselregister.com...93-hvac-heater-treater-doors-replacement.html
See link in post #23 above. Shadrach
Thanks. I had already watched the video, and the parts looked he same (hence my question). I also was a little concerned, since the heat treater videos were about cutting out and installing the new doors. I am not interested in cutting, I was more looking just to replace.
This looks great. Can you tell me where I get the new door and pivot and the part number please. 06 Megacab. Same problem.
Thanks, Mike on FL.
that sounds like a blend door problem. Remember blend door is what the air is coming out of, recirc door is just either outside air or recirculating inside air.
I answered my own question by installing it. The damper plate, new servo and pin were the only parts I installed. It's working. I saw where they added stops in the housing on the new one too.
My truck is an '05 and you have to take off a lot of plastic panels to get to the same spot as the '06 pictured.
Good thing you answered your own question -
as you're asking on a thread with a last post of over a *year* ago. .
