Recommendations for Cummins mechanic/shop in Knoxville, TN
Need to figure this out now
2007 5.9 auto P0882 Code
Hi,
My 2004.5 has developed a rear pinion seal leak again (second in the span of a year). The first time it was replaced at a dealer. Started leaking again in about 3 months. The second time at a small shop with a Mopar seal. It is leaking again. I suspect there is a deeper problem -- either bearing (though, there is not whining sound or shake), or maybe the yoke or something else). The truck has about 160K miles.
Can anybody provide any recommendations for a good, honest and reasonable mechanic / repair shop in the Knoxville, TN area?
Thank you.
-joseph
Check with City Diesel. I think they are on Callahan just off I-75 in North Knoxville. If they don't make that repair, they will recommend someone who does.
an out of balance driveshaft can make a good seal leak. check your driveshaft carefully, even let it balance to be sure about its condition.
been there done that.
@GaryOwen, Thank you for your recommendation. I will definitely check out City Diesel.
@Ozymandias, I think you are very correct. It is probably my driveshaft. I will try to check it out before replacing any more parts.
Thanks to both of you for taking the time to respond.
