Red Valve Cover Gasket ?
i need to go to a dealer
Abbott Speedometer Corrector Help
My red valve cover is due on monday and I was wondering if it is possible to use the present gasket with the new cover? I currently have 5000 mi. on the truck. Cummins wanted almost $40. 00 for a new gasket and I thought if I could not reuse I would look elsewhere for the gasket set. Also is there a torqur spec. on the cover bolts? I can probably answer my own question if someone can tell what the gasket is made of.
2001 2500,AUTO QC,4x4,SWB,SLT PLUS W/LEATHER,HEATED SEATS,PWR ALL THE WAY,4:10 LSD,PERFORMER IAS, WARN,MAG-HYTEC DC&TRANS DD,TRUCK TRUNK BOX,KC,PATRIOT BLUE W/AGATE INT.
I used the original gasket when installing a red Cummins vc on my truck. The original is a thick gasket, seems pretty durable.
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with Goodyear MT/R 315/75R16, Smittybuilt stainless nurf bars, ExTang BlackMax tonno, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!! "I AM GLAD I DID NOT BUY AN AUTOMATIC, JMO"
H. O. RAM, I see in your sig. that you are runnig the Banks high ram, where did you get thisand how much?
Yeah you can re-use the old gasket,but I went ahead and put the extra $40 worth in anyway. It took care of my slight old leak coming down the right side of the motor.
Forget the torque,the bolts that hold the valve cover on are shouldered. Tighten them down until they stop. That DOESN'T mean impact them until they stop!
P. S it will look cool in the engine compartment.
Hi Steve, The best price I could find on the High Ram was at www.woodlawnrv.com.
$255 plus freight. They are in New Jersey.
Originally posted by Evan A. Beck:
If it tears, you'll be out $40.
Evan and Steve, I was quoted $68. at Cummins NW (Renton) in Nov. /Dec. '99 #ad
burndog, the shouldered bolts are only used on the '00+ valve covers which can be identified by the small hex head (as opposed to the larger earlier valve cover bolt heads).
[This message has been edited by John (edited 05-14-2001). ]
Originally posted by H. O. RAM:
$255 plus freight.
With a previous remark you made in another thread about the price The PowerShop quoted you on the Banks High-Ram (being too high), I would just like to point out that I paid substantially less than what you just said you did. Oh well. #ad
(so did several other NW BOMBers)
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
