Gary, I agree that reducing weight of oil has an effect on mileage and the EPA has taken control of the matter and practically forced companies to comply.
HOWEVER, I've rebuilt several motors before and i can tell you modern engines have significantly tighter tolerances than engines of the 50's, 60's and 70's. These tighter tolerances will require different oil to lubricate properly. I pulled my 73 toyota landcruiser engine down and could practically move the whole crank back and forth, i checked the specs and i'll be damned it was barely out.
As far as argueing about weights, its really irrelevant, the manufacturer tested the weight they suggest. This means they KNOW that it works, now i'm sure others will suffice, but you go into that without that knowledge.
Personally I really doubt that a heavier oil will harm the transmission, i didn't design it, i didn't test it, i'm just assuming. I just chose to use the recommended weight, i did not stick with the recommeded brand because thats just their way of saying buy our stuff. I won't let anyone work on my truck but me, so i take that risk, and i'm ready willing and able to risk a transmission, I'll just get a new one.
