Engine/Transmission (1994 - 1998) reduced boost
Engine/Transmission (1998.5 - 2002) Egt
Driving back from the race track pulling my trailer I noticed that I was no longer getting 30 psi of boost. I have a '97 with a TST #11 plate. The truck is producing about 24-25 psi, but the EGT's are running about the same as before. (1250 pre turbo, full load) I changed the air filter, since the other was a bit dirty. no change in boost. Now I'm wondering what to check for now. Loose hoses? thanks.
definately check all your boots, and clamps. i had low boost and found a hole the size of my finger in one of the boots. do a seach on how to make a pressure tester, and pressurize the system. you should only need about 10psi to find your leak if you have one. do you have a waste gate? if you do, check to make sure it's not stuck open.
