I used a similar hitch. It worked fine. I upgraded to a better hitch since I use the trailer more but if you are only going to use it on a limited basis, the Pro Series will do a fine job. NVR FNSH is correct in that you need a rubber hammer to get it into the bars and a pry bar to get it out but even that's not a lot of work. I used to put on my work boots, get three pins into the bars, and then give the fourth pin a good kick. With this hitch, you also have to double check to make sure you are really hooked up when the bar slides in because it is sometimes possible to look latched when it isn't.
