2nd Gen Non-Engine/Transmission Relaying headlights
Engine/Transmission (1994 - 1998) Oil Pressure
2nd Gen Non-Engine/Transmission drive shaft?
I want to add relays to the headlight wiring on my 99 Dodge 3500. Can anyone tell me when they went from switched power to switched ground? When I checked power at the headlight harness plug I had 11-12V at pins
A-VT/RD & C-RD/OR on low beam and A-VT/RD & B-VT/WT on high beam. Should it be showing voltage at two of the pins on both low & high beams?
Rick.
I found my fluke VOM is to good - with ac/+dc & -dc the meter jumps around, etc.
The best for a on/off is one of those $4 lighted ice pick testers. With headlight switch OFF,
switch using hot= first look for ground wire (tester lead on + battery). Then find low & high wire with tester lead on -battery and the headlight switch in on position.
switch using ground= first find hot wire(tester lead on - battery) Then find low & high wire with headlight switch in the on position.
