JHardwick said:I thought this was gonna be a good thread when it started, but I'm almost as confused now as I was before :-laf
I thought my rough idle, intermittant high pingy idle, loss of fuel mileage, seemingly loss of power etc etc was gonna be because of a bad relief valve. And I would have understood due to running an EZ for almost 150,000 miles. But, based on this thread, my relief valve is good and my CP3 isn't.
I pulled the banjo bolt and pulled the line back out of the way. At idle I stuck my finger over the relief valve like you would a garden hose and got a small fine misty spray out from around my finger. At the same time, fuel was dribbling out of the return line. Not hard enough to spray to the opposite of the inside of the banjo fitting, but a good solid dribble.
Is it my relief valve? CP3? Or as RBattelle suggested, my FCA?
I finally found what sounds like a reputable shop about 30 miles away, but as usual I'm leaving in the morning and won't be back until Sunday, they can't scan it until Monday.
i would say your relief valve is bad due to it leaking, cp3 sounds normal
