I SECOND VeeTenJeff!
RCBS's Master Reloading Kit (it includes the famous Rock Chucker press) is the way to go for all of V10Jeff's reasons. It's real important to learn and master each step BEFORE going to a progressive press. RCBS is guaranteed for life. They'll even remove stuck cases from RCBS dies for free!
Also know that when it comes to straight wall cartridges, CARBIDE dies eliminates the need to lube. A real convenience.
Once you find brass you can expect it to go at least 5 or 6 times through. Next to bullets, this is the most expensive component(sometimes it's the most). What you'll learn is, how nice it is to choose to load low power plinkers or load to 90% max to really make that 41 bark!
Having more than one reloading manual is nice as well. You can always look up a "second opinion". I have many manuals and am allways grateful for the additional info. SPEER reloading manuals are always a great source for REDUCED loads, and reduced loads merit just as much caution as normal loads for different reasons.
Just take your time and be careful. A double load of gun powder will easily fit in the magnums case and will most certainly injure you and those around you!
R/ Ian.
