Installed the Vulcan big line & pump relocate kit today. My first impression is very good. Run the truck about 5 miles today. Idle was 15. 5 lbs. Running down the freeway at 65 was 13. 5 to 14 lbs. Normally it is about 11 lbs. Will know much more after I run it pulling. The only sorta negative comment is that there was metal filings in a couple of the fittings and I never received any washers in my kit. Is the fitting that is used to install a schrader valve the same one that is used under the fuel filter can for guage hookups? I noticed my lift pump whineing as well. Anybody have a whine noise from lift the pump. My bracket is insulated from the frame etc.
Thanks - J
Thanks - J
