Got nervous after reading numerous posts about low fuel pressures. Hooked an A/C gauge to the port on the fuel filter. 8 psi at idle, 5 psi just revving the engine. Duct taped the gauges to the window and road tested with the PowerMax3 on 9. Fuel pressure dropped to almost 0 psi when the boost shot up over 30 psi. With DD2's and a Con OFE here in a box and an HX40 and Jardine exhaust in the works, I'm sure I need more fuel! Should I relocate the stock pump or add another pusher (e. g. Enterprise kit)?
________________
Jaguwire
2001 Quad Cab 4X4, Permatech liner and coated Westin bars, Powermax3 Adj. , Ceramic clutch disc (Grabby), PacBrake
________________
Jaguwire
