REMOTE MOUNTED OIL FILTER SYSTEM
Stockton Wheels
3rd brake light cover
Looking for the best pricing on remote mounter oil filter system. Do you think it is worth it to put a diesel engine. Where is the best location for this system on the truck.
95 2500,4x4,Laramie,Automatic,Emeraid green,Equipment add on,Home made brush guard with fog lights,and modified block heater,2 pin removable,Cab guard protecter,which i hold the patent on it(mading web page on it soon),15k trailer hitch, used for 7'x 12'dump trailer + home made 5'x 8'dump trailer + 7'x 16' car trailer,cobra cb 148gtl, vent shades,4" open exhaust,getting set up to up grade diesel motor
I'm with ALASKA BEE. If you're having a hard time getting to the filter to put a wrench on it, unclamp the intake tube off the turbo and rotate it out of the way. Gives much better access.
Chris
95 3500 CC SLT Cummins auto
TST 230hp kit, TC lockup switch, TransGo.
Isspro EGT, trans/rearend temp, boost gauges
A-Pillar Mounted
Scotty Air System, Factory Cat-Delete Pipe
