remove turbo silencer?
'03 HO Air Conditioning not so cool
Do I need gauges?
do a search under silencer ring and you;ll find what you need
anyways... . pull the filter tube off the front of the turbo. Look at the turbo and around theoutside of it is a "snap ring" take a small screwdriver and gently pry it out, then the silencer ring will be lose, just pull it out and the silencer ring is removed. on a 1-10 scale its a easy 1
Hope this helps
Ian
On a scale of 1 to 10 of the cool factor... It's a 10! Love that whine. The 'Strkoes are still louder though.....
*note* take your belt off or use a fender mat, bending over to get dads silencer ring out of his 05 was a close call on the paint
Ian
