Removed the 370's!
Dyno Days
Dana 44/60 swap
Joe,
You win the cookie! I loosened on all my injector lines last night while the truck was idleing. The number 5 cylinder is causing the rough idle.
The truck runs very rough with any of the injectors loosened, but when I loosen the #5 injector, the noise gets slightly louder, but the engine doesn't shake as much.
I took out my delivery valves and compared them hoping to find a problem. But of course, I didn't. I assume the problem is internal to the pump and I will just live with the roughness.
Thanks for your input. I can admit now that I was wrong for assuming the 370's were causing the roughness.
I would put them back in, but I just installed them in a fellow TDR members truck (also a '94) to compare. He is going to test them for a week.
-Chris
Chris,
Maybe the best thing to do is to pull your pump and have it calibrated and repaired at a good Bosch shop.
The best thing to do is get a new pump from Piers. Too much $$$ though. #ad
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
Coming Spring of '01: DD III's, Majestic prepped HX-40, ATS Pulse Exhaust Manifold, High flow delivery valves, Gov spring kit.
Chris,
While I remember, have you switched your small 160HP Vibration Damper (Harmonic Balancer) to the larger & heavier 215 HP one?
The 175, 180, 185 & 215 HP engines all use the same big one.
Only the 160 HP truck comes with the small one. Its a direct swap. You will need to adjust the tach pickup.
Its Cummins p/n 3924435 about $175 if I remember right.
