DPohl said:I was wondering if I get a performance chip/module, will the dealer know it was there by some sort of coding or something if I remove it for any warranty work?
Thanks-
Dave
tschwab said:Dave,
You didn't say what type of warranty work. Is it for a problem your chip caused? If so, you should be denied warranty service as you have now comitted fraud and the dealer should void your warranty.
I can't believe the number of people on these boards who want the dealer to fix their trucks because they have added mods and then don't want to take responsibility for the repair. What your doing is raising the dealers/DC cost of the truck for all of us in the long run.
You turn up the power, you then become your own warranty station. KUDOS to DC for clamping down on this. I hope they get even tougher on it. My . 02 worth.
TWest said:I guess DC should send a check to all the owner that have Mods that are thier own warranty station ,Or at leased A refund on the residual. Or the option at reduce cost when purchasing. what if you added a brake controller and it voided your wiper motor because it was plug into your electronics, or a remote start, or lights to the running boards.
Yes Some of the Mod"s are GTB"s GO TO YOU BLOW. Others have safety features build in That are better than stock,Look at all the truck today that have gauges. None of the Big three install a EGT gauge and program A max temp ,Or even a warning light or sound. YES you can BURN down a stock engine which could be easily avoided with a senor.
tschwab said:Well if you would have read the 1st post, you would know he was talking about a performance chip, which DC should VOID any warranty for problems arising from the chip.
If I should burn down my "STOCK" motor, guess what - DC is my warranty station.
Thanks-
Dave
DPohl said:I have just registered on this message board for the second time, first time was about 3 or 4 years ago. I think I have posted twice and both times it has turned into some ******* match of attitudes and personalities. Is this the norm for this group?
