Repair Tip
A Dogs Prayer
This ain't no practice life guys.
When ever I have a problem with anything I just use my trusty swiss army 1-D-10-T tool!
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, All acc's w/leather
BD exhaust brake, dash mount Banks guages, Mag-Hytec Diff. cover & trans. , SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
Squeezed in a tube of Form-a-piston and was on my way.
Y2K+1 3500 4X4 Quad Cab Powerpacked , Jakit's Front End Leveling Kit with 255/85R16 BFG M/T's Custom Rhino (as seen on website under tool man's truck feature) http://www.rhinoliningsnlc.com DeeZee Goodies.
Keeping the rubber side down 'n' shiny side up Will Bring a smile at the end of each day (hopefully)
Vaughn, the Glove Box Control Module (GBCM) that Andy mentioned won't be a factor in your ETH. For the 2001's, Dodge changed the electrical system from switched negative to switched ground. I would check the FPS (Floormat position sensor), and the CCHTCM (Center console hinge tab control module). If neither of those are reading nominal 240volt, the problem is most likely in the engine. My guess would be clogged spark plug wires. A liter or two of a GOOD QUALITY drygas should cure it - otherwise you are going to have to look at a complete rebuild - a good shop will do all the extra's too such as inspect the fog lamp belt for wear, lubricate the clutch, and make sure the exhaust filter is functioning efficiently.
The spark plug wires that I bought for my Cummins are too short. Now where did I put that "wire stretcher"?
Aritcat, I'm actually running a switched floating ground system on my 2001. I have rubber insulator tires on my beast, so therefore, I have no direct ground path #ad
I have further BOMBed my electrical system by installing multiplexed electron aligment magnets around each battery cable. This complete electron management system precisely synchronizes electron velocity and timing, enhancing inter-electron harmony. This results in efficient electronic propegation throughout the entire wiring system of the truck, increasing electrical component efficiency, and reducing wasted heat. #ad
Vaughn
'01 2500, QC SB 2wd, 6-speed, and 24-valve Cummins Turbo Diesel featuring the supercomputer-controlled VP-44 fueling system.
* *PS. . . anyone looking for flashy B/S advertising, email me * * #ad
[This message has been edited by Vaughn MacKenzie (edited 02-09-2001). ]
Gee..... I had one of those Handy Andy tool kits when I was a kid. 40+ years ago
Andy P ... ... Was that yours?
Ron
2001 2500 SLT+ 4X4 Auto Cummins, 3. 54,Quad cab,Short Bed,Camel Leather, White Exterior, Sliding rear window, Camper Special Group, Towing Group,A. R. E cap with rear door, New 30' Cedar creek 5th on its way.
I think Andy has been reading some of my post over in the First Gen. section !!!!!! DDDDDDOOOOOOOHHHHHHHH!!!!!!
92 Ext. Cab, Auto trans. , 3. 54 Non-LS, Isspro Tach, 16 cm housing, PW injectors, no name 3 Gauge cluster, 230,000+ miles, straight pipe, old and abused but still running strong!!!!
Originally posted by Papa Joe:
My choke actuator was rubbing the torque arrestor sensor. Didn't catch it, so the teeth on the idler pulley are toast. Life sucks. #ad
PAPA, I have not had the pleasure of meeting you yet... but I gotta ask were you alone when you "choke actuator" was rubbing? #ad
Didn't expect you were!
Whats the latest on your truck?
Hope yooze doin good!
Mike
9535hundred
I thought the exhaust filter was ditched in favor of the extra can of "formavalve" 1Jan98.
BTW, haven't seen any of the white stove-black for a while (maybe JC Whitney?)
Papa Joe, if your faulty choke actuator led to the de-teething of the idler pulley, you may have a case for arbitration, but if they find one trace of Chevy fender within a quartermile of the circular guidance control, the warranty will be summarily voided.
This clause was added to all the "fine print" about 14 minutes after the first failure of an idler pulley, back in March of 1702, when it was discovered that certain choke actuators were being subjected to excessive pulling by certain members of Boston's idler population.
This verbage was unanimously approved by the RSRCEoL (Royal Society of RectoCephalic Enumerators of Legumes)
The Massey-Furguson Act has no bearing on excessively pulled idler chokes, be they toothless or otherwise, due to the fact that there's no aftermarket accessories (aside from Chevy fender) involved in this issue, which seems to affect 5 out of 5. 2 statisticians.
Hope this clears things up.
<font color=blue>Heres my tip for ya :
<center>Listen</center>
<EMBED SRC="http://server3004. freeyellow.com/katdiesel/Sounds/gibberish. wav" AUTOSTART=TRUE LOOP=FALSE HIDDEN=TRUE></EMBED>
Good grief, guys. Andy,you sound like my fiancee when we first met 3 years ago. Her mother and sisters still talk like that.
Oh, by the way, my doomaflatchie valve seems to be stuck shut; any ideas on how to get it open. It is really affecting my whosamawhatsit and I have heard may shell my muffler bearings (forgot to change them every 10K). MNCumminsLVR- change the filter every other time you change the blinker fluid. About every 1000 uses, which means no one around here ever has to change theirs.
Daniel
Daniel's current truck: 1993 W350 club cab, 5 speed, treadplate aluminum flatbed, 4. 10 rear end, straight pipes, K&N, "slightly" tweaked pump. ISSPRO color coded pyrometer and 50psi boost guage. NRA Life Member (since age 12) and d@mned proud of it. IRBCTS.
