After much troubleshooting with OBDII scanner, pressure gauge, DVM, replacement pressure soleniod & sensor I've come to the conclusion that the gov pressure soleniod output in my PCM is bad. Probably the output stage transistor but haven't looked inside the PCM yet to see of the transistor is replaceable.
Question #1 is... Does anyone know of a souce for PCMs? I called Longhorn Dodge allready about a rebuild. Was wondering if there is anyone else that sells discounted PCMs?
Question #2 is... Does anyone know of a souce for male and female mating connectors that the PCM uses?
I'd like to relocate the replaced/fixed PCM into the passenger compartment where it belongs in the 1st place. Underhood heat is definitley not good for electronics. Can't understand why Dodge put it there in the 1st place (lazy or cheap or both!?). Especially, with a very hot turbo nearby.
Listen up DODGE engineers! My 17 year old 200+Kmi, Toyota 4Runner has it behind the passenger kick panel. When/If Toyota make a 3/4T TD I'm there!
TDR members, sorry for the vent but after; crappy Torque converters, KDPs, Fuel return lines, Fuel gauges, starter solenoids, etc, etc. I'm starting to get a little fed up!
BTW, I'm an I. C. engineer so diggin into the guts of the PCM is no big deal.
Any help finding these parts would be appreciated. Thanks
