Replace your flexplate when upgrading your auto!!
stock max hp for 48re
a couple of ?
wHOAAAAAAAAAAAA...
Richard, your pic doesn't look like the one in my truck ???? :rolleyes: Closer look there is a big difference in being a true Billet solid piece vs. a welded want-ta-be ??? :-laf :-laf Flame on.
Smokin Joes 2500 said:
How come all these manufacterers are listing these to '04 and thats it??? Ive got an '05 getting ready to do converter and valve body but all I have is an Edge EZ. Planning on towing normally I dont drag race. Might want to hook sled once or twice. Probably upgrade to BD ram X-power the smaller one, and an intercooler later.
So does anyone know the answere to this??? Do I NEED the flexplate with my power and intended uses????
transmission
Is the BD unit a good piece for what Im doing or should I look elswhere? (converter/valve body) Remember Im not going for 600 ponies at the wheels!
just ask yourself "do ya feel lucky?" do you want to tow your truck home, pull the trans and add it later?. I paid under 500 bucks, the tow alone could be a few hundred.
-robert
Joe, y don't you just call Bill or Stefan at www.dieseltrans.com and ask them??
It will only take 2 minutes of your time and you will get the definitive answer!
My guess is YES, you should go billet. If you are going to be hooking to a sled with the dynamic loading that is involved, there is no way that I would NOT put a flex plate in it! even if your horsepower is stock.
-robert
are you talking flywheel or converter valve body??? You quoted my converter valve body question.
So why are these companies saying flywheel for 03-04 dodge what gives? Is it the same flywheel for my 05???
Access cover plate
cali-600, Yes their is a small access cover plate that goes over the holes in your picture. This is where you access the T/C to flexplate bolts. If I could figure out how to resize the pictures correctly I could attach some for reference. I think I have the picture resize under control so here's a picture of the cover plate and the ATS SFI flexplate.
flex plate! I thought you were sold on the tc and vb. if you like lock to lock shifts then get the input shaft also.
-robert
