I have a 2000 ctd with 204,000 miles. I've replaced the lift pump and injection pump once already. I noticed my fuel pressure started becoming erratic, it would jump from 12psi going down the road to 5 or 6psi. So I got a new lift pump and put it on right away. Worked great went for test drive and couldn't get it to go below 9 psi no matter where the edge was set or how hard I pushed it. Two days later I had a job about 200 miles away. I have a fairly heavy service body on it and I hooked up a trailer that weighed at the most 3000lbs. On the way up it was great, at 70 mph it held right at 11-12 psi. On the return home, I had a hard time keeping it at 5 psi with an empty trailer! If I accelerated hard or pulled a hill I could easily drop it to 1psi. I had to baby it home to keep it in the 5 psi range. What happened??? Bad injection pump? Bad new lift pump??? What should I look for? I really can't afford another injection pump. Thank you for your help!!!!!
