Engine/Transmission (1998.5 - 2002) Replaced lift pump, but now loosing pressure
Engine/Transmission (1998.5 - 2002) FASS DDRP Failure?
Engine/Transmission (1994 - 1998) transmission filter ?
Bad grounds can cause issues as well. ECM may be fine, but a flaky ground can cause a voltage drop.
We have a member here that has installed a 12v cam and installed a mechanical LP and has the same problem, even with all new fuel system from the pickup tube to the overflow valve on the VP.
Have still been fighting erratic fuel pressure even after installing ddrp. Eventually it got to where it would actually run on a vacuum. So this definetly proves why people need to have fuel pressure gauges installed. A dodge diesel will run no problem with no fuel pump running. Got the 0230 code and started doing some research on here. Got it narrowed down to ECM. I found a post by Jlandry showing how to wire a relay to get the supply voltage out of the ECM. At this time I have it wired through a toggle switch, which I wouldn't recommend because someone might forget to turn it off or on. I have one that lights up when it is on and it is mounted next to my gauge. As I read all the many many posts on here about people having erratic pressure I wonder if the ECM was just giving erratic voltage. Looking back now I don't think there was anything wrong with the last two pumps I bought. Each time I would turn the key off and restart I could get a different pressure. Lately I would have to cycle the key on and off 4 or 5 times. The only way to test would be to hook up a voltmeter permanetly and drive around monitoring it for days. Mine wouldn't always act up so I never really caught on to what was happening until it finally went to 0 volts. All I know is 2 airtex and one ddrp were all giving erratic pressures but not now with their own circuit. This is with 100% all new components in the fuel system, completely aftermarket from draw straw to filter and replaced overflow valve. All along it was electrical. At least I got some good experience and learned a lot about the fuel system. By the way I also kept an airtex mounted and ready to go so I have 2 fuel systems that I can control from the cab so I will feel pretty confident on the next trip. Hope this helps somebody figure theirs out.
I had this problem last year with my intank pump. It was low and erratic. I bought a holley blue? (I think) and installed it on the frame below the tank and put a relay from the battery to the pump and used the fuse under the hood for the VP44 to trigger the relay. So, now I turn on the ignition and you immediately hear the pump running and building pressure. Both intank and Holley pumps run and I have 10-12 lbs. pressure ALL the time. The relay is mounted next to the fusebox under the hood for easy access.
Put on new vp-44, took out fuel heater and thoroughly cleaned filter housing. Replaced return line completely and now fuel pressure is rock steady at 14 to 15 psi no matter how I drive. Don't know if return line could be the cause or what but runs better than ever with new blue chip pump with new computer. After spending close to $3000 on fuel system and doing all the work myself, It finally runs right and my frustration is over.
