While performing the service of my 2006 SRW 3500 Mega Cab with 70K miles, I noticed that there was a slight gap between the sway bar bushings and the bar itself. Upon close inspection, it appeared that the bushings had worn "egg-shaped", and as a result, no longer supported the sway bar as they should. I ordered the 33mm Energy Suspension bushings (ES_95186G) from Geno's and installed them last evening. My sway bar end links were still tight at the ball joint for now, so I purchased Moog K7300 kits for each side and replaced the bushings on the sway bar end links also.
If you haven't done this yet, don't wait! Order them and get them on there!!! There are lots of things to spend it on, but this is simply money well spent! I had no idea it would transform the ride and steering quite that much! No longer do I have as much "sway" in the front end, but best of all, it made the ride much quieter when riding over normal interstate bumps and washboards (all the "normal" things we drive over now that state budgets have been cut so much that our roads are worse than they ever were!). I found that I didn't need to "cringe" when anticipating going over railroad tracks anymore!
As far as driveability goes, it transmits less of the impact shock from bumps to the steering. That in itself is worth the small investment in parts and your time to have them changed. This correlates to feeling more in control of your steering.
I will eventually save to get a pair of the Maxx links from Geno's the next time I need end link bushings or when the ball joints begin to exhibit some looseness.
Check yours out next time you roll under your truck!
