After installing the Vulcan kit (the "real" one, not the 3/8" Genos version), my fuel pressures haven't changed much. I'm still getting 13 psi at idle, 10 cruising, and I can drop it to zero at WOT.
I'm thinking I need to replace the pump, but am not sure what I should get. So far, the options seem to be:
At present, I only have the mods in my sig. An aFe PG7 Stage 2 will be installed Monday, and I'll probably end up with exhaust and turbo enhancements (not to mention a clutch). Perhaps a Comp.
Any recommendations for and/or experience with the "best" pusher pump for such a configuration?
- OEM lift pump
- FASS 150 (no filter/separator - just the pump)
- Holley blue (like I have on my '67 Mustang?)
- Mallory, other Carter, etc.
