-I replaced head gaskets on both of my 01's. The 3500 had 140,000 on it and was leaking on the passenger side behind the thermostat housing not a bad leak but it bothered me, white streaks on the block. I'm not the original owner bought it with 93,000 ten years ago.
-I replaced the one in the 2500 at 330000, I'm the second owner, purchsed truck from my friend who bought it new. My friend said it had a small leak since it was new, dealer ship could never find it. When I decided to replace it it had gotten worse with the cold weather, in the winter, it started to leave a puddle on the ground. Found the leak was coming from the front edge of the head about in the middle. On inspection I found a 1/2 inch long channel about 3/16 wide in the head. There is a blind water jacket hole in the head that goes no where in the block the channel lined up with that, over time, I assume the channel got longer (electrolisis) and made its way outside of the silicon surrounding that port in the head. Or a deffect from the factory
The machine shop brazed the channel shut and resurfaced the head.
-both trucks have 275's and powerMAX 3's on 9 all the time. 40psi on 3500, 46psi on 2500. :-laf
-The factory head gasket set is the way to go. all the gaskets and new valve seals.
-The seals for the fuel return line banjo bolt on the back of the head do not come in the kit, reused old ones on 3500 (forgot to order). Installed new ones on 2500
