I replaced my lift pump about 4k miles ago, and now I'm thinking that I need to replace the wire harness. I changed the fuel filter this evening, and I noticed that when I bumped the starter, the lift pump came on, but when I tried it a second time, nothing happened. Did it a few more times and nothing. The truck started right up and I ran it for awhile, then shut it down. I let it cool for awhile and tried bumping the starter - nothing. So I grabbed the new wiring harness that came with the new pump, and I was going to change it out. Problem is that I can't seem to get to the connector because of all the tape that's on all the wires. So I desided to clean up the old connector the best I could. After cleaning and reinstalling, the pump seemed to work fine. But I still want to replace the old wiring harness. So I started to take off the old one by removing all the old gummy electical tape that was on the lift pump wires. I only made it to the point where the lift pump wires enter into what seems like a larger wire harness. Is the other end of the connector in that harness somewhere? Is it easy to get to? I spent a little over an hour trying to get that old electrical tape off, with very little luck. It only took 45 minutes in a snow storm to replace the pump, now this little wiring harness is kicking my butt - am I missing something here? Thanks for the help.
- Mike
- Mike
