This is good, typical. A friend of my send this email. He is now another unhappy cummins camper.
Jake
Heres the email:
Details:
I own a '99 dodge with a 24 valve diesel. I heard that the timing pin breaks
off and falls into the engine causing damage. I was wondering if I need to
do something to prevent that from happening. My truck seems to be running
fine. How often do the lifter pumps go bad.
Jason
Here the response:
Summary: 1999 Dodge dowel pin
Solution:
Thanks for your Email message.
Here is the information we have on the Ram B-5. 9 dowel pin issue:
The locating dowel pin diameter from the supplier and the hole drilled for the pin, are designed to be 'press fit' dimensions. In some rare cases, the combination of the supplied dowel pin dimension and the drilled hole dimension, may not provide the correct 'press fit'. During assembly line manufacturing, it is impossible to determine the amount of 'press fit' between the dowel pin and the drilled hole, once the dowel pin is installed into the bore.
A few of the dowel pins that have not had the correct 'press fit' in the drilled hole, have worked out of the hole, during normal engine operation. If the pin works itself all the way out of the bore, it can drop down into the gear train, which may or may not cause extensive damage to the gear train and gear cover.
The percentage of failure is very, very low and does not justify a major campaign of all engines. If an unexpected failure would occur during the warranty period of the engine, the repair would be handled under normal Dodge warranty practices. The Dodge warranty period for the diesel-powered trucks is 5 years or 100,000 miles. A dowel pin coming out after this warranty period would not be considered a manufacturing defect.
The chances of failure was greatly diminished in early 1998 when the gear cover was changed to a 'blind hole' design, which would not let the dowel pin move out of the bore. If a Dodge customer has a great fear of this dowel pin coming out on earlier models, we suggest discussing the issue with your local Dodge dealer, to determine the appropriate action in each situation. In non-Dodge applications, the customer should contact the OEM dealer or the nearest authorized Cummins dealer or distributor.
If desired, to prevent the dowel pin from coming out, the dowel pin can be replaced or Locktite can be used to hold it in place, without having to replace the pin or gear housing assembly:
Steps to inspection and securing of the dowel pin in front cover:
1. Remove the damper, pulley and gear cover from front of engine.
2. Tap on the dowel pin with a flat punch to insure that it is seated in the bore.
3. Clean all the oil from area with solvent and dry completely.
4. Stake the pin and cover with a center punch. Apply some wicking type Locktite on the dowel pin and let the Locktite cure.
5. Reinstall the cover with a new seal and gasket.
6. Reinstall damper and pulley.
We hope this helps you better understand the dowel pin issue. We do not have information on the life expectancy of the fuel lift pump. Failures are random and can occur early or may not occur at all during normal engine operations.
We thank you for your interest in Cummins products. Please let us know if you need assistance in locating the nearest Cummins-authorized Dealer or Distributor Service Provider. For assistance in locating a Service Provider, feel free to use Cummins North America Dealer Locator, which can be found on Cummins website:
http://www.cummins.com/service_locator/index.cfm
Please let us know if you have other questions and if away from your computer or have a time-critical request that needs more urgent attention, feel free to call us toll-free (from North America) at 1-800-DIESELS (343-7357).
Email direct: -- email address removed --
Regards,
Powermaster
Customer Assistance Center
Cummins, Inc.
Columbus, Indiana, USA
Free QuickServe Online for Consumers http://quickserve.cummins.com
Jake
Heres the email:
Details:
Jason
Here the response:
Solution:
Regards,
Powermaster
Cummins, Inc.
