I run a stock lift pump moved back by the tank with stainless steel fuel lines (ie no banjos anywhere). It works great. I have 14-15 psi at idle, 12-13 @65 mph and 8-10 at WOT on 5x5. I would like to see the WOT press a little higher and have been considering the HP4061 as a temp fix. Then once someone get a year on that new PE4200 with out a failure I may switch to it.
What are the threads on the carter 4601 ???
JR2
JR2
