BODY CODE PLATE
The Body Code Plate Body Code Plate is located on the floor pan under the passenger seat or attached to the front face of the radiator closure panel. There are seven lines of information on the body code plate. Lines 4, 5, 6, and 7 are not used to define service information. Information reads from left to right, starting with line 3 in the center of the plate to line 1 at the bottom of the plate.
The last code imprinted on a vehicle code plate will be followed by the imprinted word END. When two vehicle code plates are required, the last available spaces on the first plate will be imprinted with the letters CTD (for continued)
When a second vehicle code plate is necessary, the first four spaces on each row will not be used because of the plate overlap.
BODY CODE PLATE - LINE 3
DIGITS 1 THROUGH 12
Vehicle Order Number
DIGITS 13, 14, AND 15
Open Space
DIGITS 16, 17, AND 18
Car Line Shell
BR1 = 1500 4 X 2
BR6 = 1500 4 X 4
BR2 = 2500 4 X 2
BR7 = 2500 4 X 4
BR3 = 3500 4 X 2
BR8 = 3500 4 X 4
DIGIT 19
Price Class
L = Ram Truck (All)
DIGITS 20 AND 21
Body Type
31 = Ram Truck Club Cab (138. 7 in. Wheel Base)
32 = Ram Truck Club Cab (154. 7 in. Wheel Base)
61 = Ram Truck (118. 7 in. Wheel Base)
62 = Ram Truck (134. 7 in. Wheel Base)
63 = Ram Truck Cab Chassis (138. 7 in. Wheel Base)
64 = Ram Truck Cab Chassis (162. 7 in. Wheel Base)
BODY CODE PLATE - LINE 2
DIGITS 1,2, AND 3
Paint Procedure
DIGIT 4
Open Space
DIGITS 5 THROUGH 8
Primary Paint
Refer to Body for color codes.
DIGIT 9
Open Space
DIGITS 10 THROUGH 13
Secondary Paint
DIGIT 14
Open Space
DIGITS 15 THROUGH 18
Interior Trim Code
DIGIT 19
Open Space
DIGITS 20, 21, AND 22
Engine Code
EHC = 3. 9 L 6 cyl. MPI Gasoline
ELF = 5. 2 L 8 cyl. MPI Gasoline
ELN = 5. 2 L 8 cyl. (CNG)
EML = 5. 9 L 8 cyl. MPI Gasoline
EMM = 5. 9 L 8 cyl. MPI Gasoline (Heavy Duty)
ETB = 5. 9 L 6 cyl. Turbo Diesel
EWA = 8. 0 L 10 cyl. MPI Gasoline
BODY CODE PLATE LINE 1
DIGITS 1, 2, AND 3
Transmission Codes
DGB = 4 - speed Automatic (47RE)
DGT = 4 - speed Automatic (46RE)
DGK = 4 - speed Automatic (42RE)
DDP = 5 - speed Manual (NVG-4500)
DDX = 5 - speed Manual (NVG-4500 Heavy Duty)
DDC = 5 - speed Manual (NVG-3500)
DIGIT 4
Open Space
DIGIT 5
Market Code
B = International
C = Canada
M = Mexico
U = United States
DIGIT 6
Open Space
DIGITS 7 THROUGH 23
Vehicle Identification Number (VIN)
Refer to Vehicle Identification Number (VIN) paragraph for proper breakdown of VIN code.
