Reverse Alarm
63lph injectors
where to find a good deal on a stock style flex plate ?
How do you disable the horn when your in reverse with the door open its on a 07 2500 MC Laramie 3. 73
Cant, as far as I know... It was a recall for early 3rd gens, and carried in programming to the newer trucks. As far as I know, we are SOL :mad:
This was something that was added to the software in the truck and if you ever go to the dealer and they reflash your ECM you will get this back-up-door-open alarm. They might be required to do it. I know a guy that had it done to his truck and he used a Dodge DRB computer to try to find it in the program and disable it and he couldn't do it. It is non-reversable at this point. I have heard of some guys putting in a switch to turn off the horn while backing but other than that I don't think you have a choice
If it is like the '06 you can unplug the seatbelt sensor wire from under the driver's seat and put a jumper across the pins. An electrical female spade connector works fine. That way you can just remove the connector and re-insert the original plug if you want to return to stock.
