Reverse slipping
Where is Pruven Performance?
Scratches out of Pearl Coat
Noticed that reverse in my auto transmission was slipping the other day. Went over my records and found that I had serviced the trans about 8000 miles ago but had probably mis adjusted the rear band. Read the manual wrong and adjusted to to 2 turns out instead of three. When I opened the pan I found fluid that looked like motor oil and some sludge w/ a few metal chips around the magnet. Changed the fluid and re-adjusted the band to 3 turns out and it seems to be ok now... . but I haven't drivin it much except to test it. Any thoughts?
98 2500 club cab 4x4 12v 410 rear, tow pkg, linex, ARE utility top, unbombed to the max
Having the band adjusted too tight and causing it to drag could have glazed the band. These normally won't heal themselves. Hopefully the band isn't hurt too much. If it is you'll notice the slip is still there. If the trans has to come out in the future, it would be a good time for the DTT conv/vb upgrade. Good luck.
you should check the pressure in the port for reverse, its the one facing the back. Mine was slipping a little because my pressure was to low, it should be 300psi+. You might need a new valve body. Something to remember is the reverse clutches are the same as 3rd gear so if your not slipping in 3rd its probably just the valve body.
Thanks to BD for getting my auto working correctly behind my beast.
96 4x4, 3. 54 posi, 6. 5"lift, 35" bfg m/t's and 35x14. 5x16. 5 boggers,dual stabalizers, aluminium wheels, sport headlights,billet grill, K/N 0880, NOS, Performance Diesel LPG, BD Pulling/Competition fuel injection pump,370hp marine injectors, ported head, Hx40 w/ 16cm2, 4" exhaust w/ 2 chamber Flomaster, BD copetition auto transmission and torque converter, Kenwood sterio System, Westach 60lb boost/ egt guage with warning light,aluminium bed rail covers,chrome diff covers, 5 foot traction bars,
475hp and 1050lb of torque on #2
530hp and 1140 with bullydog lpg maxed(only 55hp)
590hp and 1200 with lpg and nos
all done in 5th gear with 35's.
have a great day.
Adam
I brought my truck to the "stealer" for a trans service only to find they didn't have a torque wrench that worked, didn't know how to make the different pressure tests but they did know that I needed a complete rebuild for my trans. My symptoms are: early shifts, slipping during shifts, and reverse slipping although it has gotten better since I adjusted the band. So I've been reading the service manual and found several adjustments that might work: throttle valve cable, line pressure, hydraulic pressure test etc. These test procedures seem to be for gas engines. Does this make a difference?
