Review: Rancharo 9000 shocks
DTT TC and stuff
Turbo Silencer Ring Purpose?
Review: Rancho RS9000 shocks
Last weekend I replaced my OEM shocks with Rancho RS9000s on the front and rear. Here is a review of my results.
First, I chose the Ranchos because of all the favorible comments made by memebers of this board. I had also decided to add air bags, but was advised against it by some folks on this board. I was told that if I put on the Ranchos, since they are adjustable, air bags would be a waste of money. I was very doubtful of this advice considering the amount of weight I tow.
When I installed them I went by the directions Steve St. Laurent had in TDR 31, page 12 and 13. Without Steve's directions I never would have been able to do the job. (Note: I am only a WIWA mechanic... (WIWA=Wish I Were A. )) The directions that came with the Ranchos were crap, and the Dodge Service Manual helped, but Steve's directions were great! Thanks Steve.
I only had one problem with the install, the bottom rear bolt that holds the right rear shock in place could not be pulled out once the nut was removed. The bolt hit the sway bar. Thanks to the fellas who came to the rescue with advice about what to do to fix the problem. Look up my other thread for more info.
I replaced the shocks last Saturday. Sunday morning we hitched up the 5er and pulled to Townsend in the Tennessee Smokies.
The trip is about 150 miles up highway 411. Hwy 411 is mostly a two lane state highway that has some ups and downs, and goes through a bunch of small towns. The highway is pretty good, but there are several long stetches of construction, bumpy surfaces, uneven pavement, etc. A good test for the shocks.
Before we left we weighed the 3500 (7,650 lbs with me, my wife, supplies, and a full fuel tank), we also weighed the 5er seperate. It weighed 14,230 lbs. Total weight was 21,880 lbs.
Our 3500 has a GCWR of 16,000 lbs. , so we were 5,880 lbs over weight. The max I can have on the 3500's rear axle is 7,500 lbs. , we had 6000 lbs. , so I was o. k. there. The temp was about 90 degrees and humid. Again, this much weight is a good test for the Ranchos.
I set the rear shocks to the #5 setting and the front shocks to the #3 setting. When I hooked up the 5er I noticed right away the rear end didn't sag nearly as much as it had with the OEM shocks.
As far as pulling went, my oh my, it was much better. One thing I should add here, our 3500 has over 123,000 miles and had the orginal shocks until I replaced them with the Ranchos. I pull 6 to 8 times per month - either the 5er, horse trailer, or flat bed with my tractor aboard - so my original shocks were shot.
There was a huge difference with the Ranchos, especially when I hit a bump in the road. With our OEM shocks we'd get really bouncy in the rear. Now we got very little bounce. The truck handled much better. I was in better control.
As to whether I still need to add airbags. Nope. The advice I got was right on, and it saved me about $500.
When we unloaded the 5er I reset the shocks (which really does take only about 15 seconds per shock to reset) to 3 in the front and 1 in the rear. The feel was good. A day later I reset the front to 2 and liked it better.
Since we've been back I've kept the fronts at 2 and the rears at 1. I haven't adjusted the rear tire's air presure yet. They are still set to 65 psi (the max). Today I'll let out some of the air in the rear tires and go to 55 psi.
I've done a lot driving since we've been back, on the express way, state highways, and some country roads. I like the unloaded setting just fine.
If I can answer any questions I'll be happy to help.
Again, thanks to all those who helped me.
Bill Cook
BC: Parts of your review do not made sense!
"When I hooked up the 5er I noticed right away the rear end didn't sag nearly as much as it had with the OEM shocks. "
The Rancho 9000 shocks will not change ride height in any way. If anything, you will ride imperceptibly lower, because the OEM shocks are gas pressurized and the Rancho's are not. What am I missing here, or are you blowing smoke?
Landshark,
No, I'm not blowing smoke. I also didn't have a ruler. But I will tell you that as I raised the legs on the 5er and it's weight transferred to the fifth wheel hitch, my wife noticed that the rear of the truck didn't dip down as much as it usually did. I agreed with her, I didn't think it dipped down as much either.
As I said in my review, I'm not a mechanic, shade tree or otherwise. I don't know what shocks are made of or how they work, rather I was looking for results. I could have been very wrong about how far the rear end dipped.
I do know the truck road much better than it did before. It road so much better that I decided I wouldn't add airbags.
Hope this clears things up.
Bill Cook
Ride hight??
I agree 100% with Landshark on the ride hight. What do you mean by that. The shocks have no affect on that whatsoever. The only difference you will notice is how far they compress and rebound when you hit a bump.
I put this post in the wrong directory. Doc, can you move it to the Product/Accessory directory.
Thanks,
Bill Cook
Well if he had the OEM shocks at 123k and they were shot wouldnt they sag more then a new shock "a bit" under a heavy load?
Sky and others,
What Landshark said is correct. Unless the shock has coilover springs or is of air-lifting variety, they will have no effect on ride height.
While normally I would agree that shocks have no affect on ride height, I will say that under a static load, teh rancho's on setting 5 will "raise" the height a little. Ok, it is not raising it, rahter it is not allowing the suspension to compress as much (under static load). I conducted a little test. I have the 9000 on setting 5 all around on my 2500 2wd. I bounced on the rear on ten separate tests and took a measurement. I went around and adjusted the shocks to setting 1. Ten more bounces. I would hop off the rear bumper on the last cycle and let the truck come to rest... . This was performed ten separate times for each setting, 1 and 5. This is what I came up with
setting 5 44. 5" +/- . 1"
setting 1 43. 9" +/- . 1"
I realize that it is a very small difference, but it was there.
I do agree though taht shocks not of the HPG or coil over design do not active raise the ride height.
Oh yeah, i weigh in at about 390#, so that rear suspension was movin' and bouncin'
VeeTenJeff: I won't say that you measured wrong (especially since you weight 390!) but I would bet that if you reset the shocks again and repeated your bounce test a few more times, you would find no difference. There just is no way that the Rancho 9000 shock will change ride height.
Jeff I am amazed you don't look a pound over 375, I must say You wear it well. :D :D :D :D
See ya the 12th
Darren
Landshark and Cumminspower98,
What follows is not me being a smart ass, just an observation.
When we pulled in from Tennessee I pulled the 5er around back of the shop. After a trip I always wash and clean it before I put it away. Yesterday we washed and cleaned it. When I hooked up to move it to its storage building I paid particular attention to how far down the bed went. Again, this is not scientific, and I much admire someone like Jeff who takes the time to do a height experiment. Anyway, to me it didn't seem the truck went down as far as before the Ranchos were put on. Again, this is only my opinion and I could be dead wrong.
Another thing also happened (again, this is my opinion, I didn't take before and after messurements): When I lowered the 5er's legs to get it off the truck I got the separation gap between the 5er's king pin and my Reese hitch quicker than normal.
Don't know what this means, just know what happened.
Bill Cook
Funny, Sky, that gave me a smile.
I re-read my post from yesterday and it sounds like I'm being a smart ass. I'm really not trying to be. I started this thread just so others, who are thinking about getting the Ranchos, would know what I thought about them.
Whether my bed sags down more or less isn't really the issue. Landshark and Cumminspower could well be right, as I said, I didn't take before and after messurements.
Sky, you brought up a good point the other day, the original shocks that I replaced had 123,000 miles. I pull very heavy - between 12,000 lbs to 15,000 lbs - and pull 6 to 8 times per month. Maybe the old shocks were worn out. I don't know if worn out shocks sag more than new ones or not. As I said in an earlier post, I don't know what shocks are made of, or how they work.
Anyway, back to the orginial purpose of this thread: The Ranchos feel much better when you are pulling a heavy load. When you cross a bump you don't feel like you may bottom out. You feel like you are in a good pulling truck. When we're driving around town (the 3500 is my wife's truck) we set the fronts to 2 and the rears to1. With this setting the 3500 feels much as it did before we replaced the shocks. My wife is not looking for a harsh ride.
Hope this helps someone.
Bill Cook
I am going to switch out my shocks for the rancho 9000's. I got Schwab mt. ryders now because the basicly threw them in for free when I bought my tires and rims from them. Even these shocks are alot better than stock. I also have the rancho 5000 stabelizer that really made a difference.
Sky, can you tell me what difference the 5000 stabilizer made. I still have the stock stabilizer.
Thanks,
Bill Cook
Well I had a steering wonder issue and when I put that new shock on it helped me alot and it feels like the steering is "tighter"
