some comparisions to other combo's.
I keep the rail in check at no less then 20K. 22. 5 preferable.
I've put on software #7 with the revo. a little less smokey on slow acceleration. But not 4. 11 haze (well, 90hp injector haze). I still can't get the tires lose... with the TST settings off it clears up to a nice haze tho. seems to pull as hard as #9.
Now, with injectors in play. I'm curious if going to biggest number is really all that important anymore? with 4. 11, 7 was slower then 9. easily felt. add a little more juice with the tst on 2hp and 2rail and you got 20-22K and 50psi of boost. I can't seem to get anymore then 50psi of boost with this little II PS62. tho, I need to do a higher pressure test of the CAC system. maybe I still have a little leak? I bet my driver pressures aren't very good either. who knows.
TST alone. (ECM stock). with stock injectors. I'd run 8 or 9 tq 4 and could keep the rail in check. 10 would pull the rail down below 20K and make some smoke. Boy does this box know how to spool a turbo! SNAP! and your gone! Now with the DDP 90's anything more then 5 and I'd be draining the rail. Same turbo "snap" spoolup. This box however has ZERO smoke. even clears up the haze a good bit!
The revo vs the current TST, I'd think the revo is a step back! Tho, I think it would be fair to compare #5 (90hp tune) vs #5 HP (about 100hp) on the TST on a dyno to see for sure. The downloader will always have better low end and well, naturally the smarty runs well up to 3500rpm.
I think I'll go out to the truck now and load up #5 and then between now and lunch re-load 4. 11 and try to drive the same roads and see if I can get my acceleration back
There is a such thing as to much programming I suppose.
but in theory, with stage 1 cp3 kit and injectors, you should have to half your programming to keep the same hp level. but then again that's now always the case I suppose (as with 4. 11)
