Folks,
My RHR in my 2011 Laramie has started to act up. Over the past 6 months it has started to loose the preset satellite channel memory (resets some or all presets to Ch 184). The volume control also goes away once in a while when streaming from bluetooth (from both android and iPhone). The AM reception on the RHR has always been iffy, but now it is non-existent. Is it time I bite the bullet and replace the unit or can I fix this with a software update? If I need to replace, any suggestions on a head unit that works with the factory alpine amp, sub and doesn't sacrifice sound quality? I don't really need the nav as I use google maps or waze. I could use a set compatible with android auto, but I am not sure that tech is solid enough for daily use.
Thoughts?
Thx, Des
Thoughts?
Thx, Des
